#1027 - 11/16/03 01:42 PM Amount of grout between tiles
maggie Offline
Loc: TX
We are having saltillo tile installed throughout the downstairs of our home, except for hardwood flooring in the dining room and entry way. The installer is suggesting 1/8" grout between the 13.5" tiles -- he said if we do 3/8" grout between the tiles, it will take on the appearance of a Mexican restaurant...Any suggestions as to what would be the more appropriate?
#1028 - 11/16/03 04:54 PM Re: Amount of grout between tiles
Since I don't know what the tile looks like, I can only guess...but saltillo tile in my experience varies in size so much, that I would think it's impossible to lay it with a 1/8 grout joint. In fact even 3/8 would be too small a joint to keep the edges from sticking up against each tile.(lippage) Lets see what the others have to say.
#1029 - 11/16/03 07:08 PM Re: Amount of grout between tiles
RandyL Offline
Loc: York Region
I'd say the same thing. Most tiles Maggie vary in size a little although you may not realize it. But like Bri said, the saltillo's vary even more than regular ceramic, so if he shoots for a 1/8 joint i'd be willing to bet that you grout lines may look really out of whack when he's finished.
#1030 - 11/16/03 07:46 PM Re: Amount of grout between tiles
Bri and Randy are right. There is such a bevel to this style of tile (at least with the ones I've seen), a 1/8" grout line would not do a good job. The wider grout lines, especially the earthy grey colors work well with saltillo tile.
#1031 - 11/16/03 09:04 PM Re: Amount of grout between tiles
Check out this link:
http://www.johnbridge.com/Saltillo_Tile_Photos.htm
...as you can see, John is using at least a 1/2 inch joint..and you can still see the variation in the grout joints from one tile to the next.
3457 Registered Users
Where do I begin... 60850
Kerdi Board 39444
Kerdi over Denshield 20881
Help with preslope!! 20251
Ted's Shower 14160
3457 Members
3500 Topics
1 registered (1 invisible), 235 Guests and 2 Spiders online.
