#10320 - 12/16/06 11:56 PM drain pipes under block wall ?
2hot2hdl Offline
Loc: Palgrave
I am wanting to add a shower in my basement but there is a block wall seperating the new bathroom and the pipes running out to my septic. Is it to code if i go under the block or through it, I would prefer to go under so i can have extra height in the shower.
Dave
#10321 - 12/17/06 11:00 AM Re: drain pipes under block wall ?
Welcome Dave, I assume the exterior block wall is where the 3" or 4" existing plumbing drain is exiting to the septic tank. This is probably 2' or so below the exterior grade.
To add any extra plumbing to the basement you are going to have to add a sewage ejector which connects to the main drain up near the ceiling, plus a 2" vent up to the attic to tie into the existing main roof vent.
Is this what your asking?
#10322 - 12/17/06 04:05 PM Re: drain pipes under block wall ?
2hot2hdl Offline
Loc: Palgrave
The block wall is an interior wall and i just have to get the drain through it there is allready a sink and toilet in the basement on the other side of the wall where the vent pipe and drains leading outside are.
But if i go throiugh the wall i dont have enough heigth to raise the shower floor
Thanks again
Dave
#10323 - 12/17/06 10:06 PM Re: drain pipes under block wall ?
You need to break up the concrete floor to tie into the existing drain system including a vent line.
3457 Registered Users
Where do I begin... 60850
Kerdi Board 39444
Kerdi over Denshield 20881
Help with preslope!! 20251
Ted's Shower 14160
3457 Members
3500 Topics
1 registered (1 invisible), 235 Guests and 2 Spiders online.
