And then there's the issue of a 66" high stack of wallboard! YIKES
That could weigh what? What size sheets? Contractors usually use 12 footers, sometimes longer if possible?
Lets see....66" high is 132 sheets +-. at about 2.15 lb. per sq. ft. (I think?) That could be a lot of weight. If 4x12's maybe 17,000 lbs. Even if they cheated and used 4x8's that's about 9,000 lbs.
That's a little more than the reasonable expected load of any wooden floor I've seen. Standard construction codes call for a rating of 40 lb. per sq. ft. live load. The weight was of course spread out but still come out to about 280 lb. sq. ft. for either of my above examples.
www.tile4you.com KERDI Shower Specialist-DITRA Installs-Containers of TRAVERTINE direct, ship anywhere. SAVE 40-70%
