I think you'll find here on this site, that we all agree, that wire mesh is a waste of time and money. You might as well save that step, and put the tile directly over the plywood with modified thin set. Of course the better choices would be a layer of cement board first..or Schluter Ditra, which is a crack osolation membrane/underlay.
Also, the pre-mixed thin set isn't very good....it takes so long to dry...and it has to be completly dry before you can grout the tile...So...you are much better off mixing your own modified thin set.
