#11108 - 03/08/05 08:56 PM Halex (Plywood Underlayment Panels)
I've mentioned this product (Halex) a few times since I've used it in several jobs.
I'm curious if anyone else has used this product. It has one heck of a warranty .... "Lifetime".
I like to use it for stone installations when installing an extra layer of 5/8" plywood adds too much height. It only adds 1/4" to the substrate and has the same acceptable rating as 5/8".
Any feedback on this product would be appreciated.
#11109 - 03/09/05 12:40 PM Re: Halex (Plywood Underlayment Panels)
Andrew Offline
Loc: toronto
Hi Harry
I have never used or heard of it. But i would like to learn more about it if you have any info or links. As I stated to you in one of the other forums today hieght is such an issue with home owners.
I had another question for you. How can I find out more info on the criteria for the ceramic tile proffesional section?
Waterproofing Systems
Crack Isolation Membranes
Uncoupling Membrane
Steam Rooms
CPE/PVC Liners, Clamping Drain Assemblies
In-Floor Heating systems
Able to Identify and Correct Weak Floors (deflection no greater than 1/360)
Thank You!
#11110 - 03/14/05 02:42 PM Re: Halex (Plywood Underlayment Panels)
Ron Offline
Hi Harry
I've never seen it.First time I heard of it is when you mentioned it here a few months ago.As soon as I get a job on a wood floor(and where it's not practical to use a mortar bed)I'd like to try it,instead of standard plywood.
#11111 - 03/14/05 03:18 PM Re: Halex (Plywood Underlayment Panels)
Ron Offline
Hi Andrew
I don't know where you can find all that info at one source but a good thing to have in your library is the Tile,Terrazzo,Marble Assoc. of Canada(TTMAC) handbook,or,the US version...the Tile Council of America (TCA) handbook.
You could also look into Laticrete products for waterproofing and many other specialty systems for tile installations.Get their catalogue.
And Schluter Systems for their membranes and shower drain.
I use only Nu-Heat for heated floors.Most of my work is remodelling...old houses.I've never been involved with a hydronic installation.Schluter's Bekotec system looks like something I'd like to do if it was spec'd by a architect for new construction.
Testing questionable floors for L/360 ? I've never actually done a test with a reading.I usually just walk on it and guess \:D .
When dealing with a floor that has 2x8 joists (or lesser)and the span is too long,I don't consider setting tile on it regardless of the prep methods.Until the span has been decreased by building a wall or adding supports under it.
Sometimes,it's a bit of a gamble I'll admit.For instance,I just completed a polished marble floor where I wanted to add an additional layer of plywood,then the Schluter Ditra uncoupling membrane.But the house had oak floors and nosings and thresholds that I had to set marble flush against.And there were 5 other areas of transitions and about 10 doorways.I understood the customer's desire to have smooth transitions there.Since the floor was built with 2x12's,crossbridging and 3/4" plywood,I decided to go ahead and install Ditra(without the additional layer of plywood that is normally required)and then the 12" marble tiles.I feel confident that the installation will not fail,although,of course,it would have been better to have added the extra layer or a proper reinforced mud bed.Well...I feel confident enough with it the way it is... \:\)
#11112 - 08/10/06 09:59 PM Re: Halex (Plywood Underlayment Panels)
wernqc Offline
Loc: Montreal, Quebec
Here's the web-site of the manufacturer for anybody interested:
Halex web site
FYI: it's the 3/8" that is recommended for underlayment in tiling jobs.
Re: distribution in Quebec: I have not found anybody carrying this product; any idea
#11113 - 08/11/06 07:45 AM Re: Halex (Plywood Underlayment Panels)
Harry,
It looks like a great product. I'd love to be able to find it around here.
#11114 - 08/16/06 12:22 PM Re: Halex (Plywood Underlayment Panels)
almost_done Offline
Loc: Oakville
Where does one source out Halex in southern Ontario or Western NY
#11115 - 08/16/06 07:34 PM Re: Halex (Plywood Underlayment Panels)
Try some of the local flooring retailers
Go to the distributor web site www.brolain.com and look under contact at the bottom.
There is one dealer in London
3457 Registered Users
Where do I begin... 60850
Kerdi Board 39444
Kerdi over Denshield 20881
Help with preslope!! 20251
Ted's Shower 14160
3457 Members
3500 Topics
