#11160 - 02/24/06 11:01 PM any problems with making your own thin-set?
Tilesome Offline
Loc: Ia, USA
3 or 4 to 1 portland, silica sand?
Bradley
#11161 - 02/25/06 09:29 AM Re: any problems with making your own thin-set?
My first responce is, why would you want to make your own thinset?
Is there something special your doing that needs some custom mix or are you trying to save money?
#11162 - 02/25/06 12:25 PM Re: any problems with making your own thin-set?
Tilesome Offline
Loc: Ia, USA
In the end I guess it would be to save money, but I've torn out some tiles for a remodel and I think the thin-set was made by the guy, really dark grey and had the bond of 100 screws. Dark grey like plain portland and some fine sand. A million peices those came out in. I could'nt be sure, but it was glued w/ a 1/4 V notch over plywood and had been there about 20 years.
Bradley
#11163 - 02/27/06 12:37 AM Re: any problems with making your own thin-set?
Ron Offline
Probably was a plain thinset mixed with a latex additive instead of water.That was the thing to do over 20 years ago to make a thinset mortar sticky enough to adhere to plywood.Now,we have polymer modified thinset.Basically the latex is already in the bag.
For a superior bond to plywood,you can use Mapei's mortar called Kerabond and mix it with Mapei's liquid KeraLastic(in lieu of water).
Some stone masons still mix their own mortar to suit a particular application since there aren't too many choices for mason mix out there .But with the many varieties of tile mortar available,there really isn't a need to make your own. \:\)
#11164 - 02/27/06 08:35 AM Re: any problems with making your own thin-set?
Bradley
I think most quality thinsets are in the 1/ 1 or 1/2 range for cement to sand.
But, like the other guys said, I don't think it would be worth the effort unless you were setting huge flagstones that would require a huge amount of thinset.
#11165 - 02/28/06 06:42 PM Re: any problems with making your own thin-set?
Tilesome Offline
Loc: Ia, USA
thanks guys, I can check that one off the list...
Bradley
