#11345 - 11/18/06 11:31 PM a better blade for cutting marble
garyfo Offline
Loc: Clearwater bc
I am a DYI'r, I am looking for a saw blade to cut Marble, Granet, and Travertine that will not chip the edges of the cut. I am looking at the Target Superlox GM blade which claims to cut chip free. I have a 7" tub saw. The blade is expensive $140 but I would be fine with that if it works as advertised. Any experience with the product?? Any other suggestions??? Also while rooting through the Target catalog I found a product called Dri Bit for cutting round holes in ceramic and stone in 1", 1 3/8", 1 5/8", and 2", I thought it might be useful in the shower; again the same questions. Great forum, thanks for the opportunity.
#11346 - 11/19/06 01:29 AM Re: a better blade for cutting marble
RandyL Offline
Loc: York Region
I'll just comment on making holes in tile. You don't need any fancy core bits, unless you need perfect cuts, which is few and far between. A good grinder with a good wheel will give you the same reults. \:\)
