Page 2 of 2 < 1 2
#11372 - 12/09/06 06:40 PM Re: Silicone Caulking
Bob
The tec caulking won't stick to the pure silicone. It will eventually come loose. The Tec stuff will work just fine for you. Like Randall said, it does shrink a lot....so after you let the first bead cure a few days, put another of the same stuff on top. That should do the job for you.
By the way, the transparent silicone I use is from a company called Nutone.
The one you have, which is latex based, will come out of the tube white, but as it dries it turns clear. Sort of a neat idea really, since you can see what you are doing as you apply it. If you make a nice neat white joint, you know for sure when it turns clear that it will be a great job.
#11373 - 12/18/06 01:36 AM Re: Silicone Caulking
tile with a smile Offline
Loc: Washington
Try your local solid surfaces dealer or. http://www.colorriteinc.com/colorsil.htm
Page 2 of 2 < 1 2
