#11477 - 06/21/07 03:04 PM Liquid membrane PRP 315 instead of a kerdi membrane?
animek Offline
Subjet: tile shower.
My local tile supplier does not have any Kerdi membrane product, but sells instead a liquid Membrane called PRP 315 that should not be apply higher than 8” on the internal shower siding. Anyone has ever tried this product to isolate the walls for a tile shower? Any good?
Kerdi product is hard to find, although I am in the Montreal area.
#11478 - 06/21/07 05:34 PM Re: Liquid membrane PRP 315 instead of a kerdi membrane?
That's a product made by Mapei, that I can't say I've ever tried. They have so many. ;\)
Kerdi and the Kerdi system, including the Kerdi drain is a great product, and is made in Montreal. You should be able to find it easily. Home Depot will have it. \:\)
#11479 - 06/21/07 11:31 PM Re: Liquid membrane PRP 315 instead of a kerdi membrane?
www.tile-experts.com will have everything you need to do a Kerdi shower, and they'll ship it to your house.
#11480 - 06/22/07 12:33 AM Re: Liquid membrane PRP 315 instead of a kerdi membrane?
plotter Offline
Loc: western australia
we use all paint on waterproofing in OZ,its a bylaw now in most states....
we have a new one out now and i painted a single sheet of newspaper with two coats and have filled it with water for a week now and no water has come through and it has a bit of flex as well.good product and easy to install.......
have a good weekend all
plotter
#11481 - 06/26/07 04:28 PM Re: Liquid membrane PRP 315 instead of a kerdi membrane?
animek Offline
Thanks for the info guys!
#11482 - 11/22/07 03:43 PM Re: Liquid membrane PRP 315 instead of a kerdi membrane?
Motti Offline
Loc: CA
Myself I always used and always recommend the liquid waterproofing, the are many brand, every contractor will recommend on one he has good experience with, I believe most are good product , if not, we will not sale or buy them.
In regard to the sheeting membrane, use it once, and will not use it again, extra time/labor and not cheap at all. Apex $120.00 for standard shower 3’ x 3, x 67 \:\) while the Liquid are 1 step ( 2 coat) process apex coverage/cost per shower $70.00 2+ gallon maybe even less.
My recommendation is the pro red from C-Cure I had lots experiences of selling and using it myself.
www.flooringsupplyshop.com
Flooring and Floor heating supplier
#11483 - 01/20/08 06:51 PM Re: Liquid membrane PRP 315 instead of a kerdi membrane?
Cris Offline
Loc: Toronto
Try REDGUARD. It expensive as hell, but boy does it ever work.
Give it 2 coats (apply only on CBU) and then you mortar and tile!
3457 Registered Users
Where do I begin... 60850
Kerdi Board 39444
Kerdi over Denshield 20881
Help with preslope!! 20251
Ted's Shower 14160
3457 Members
3500 Topics
