I just installed 600 sf of Torreon 16x16 mexican travertine. I used a recommended waterbase sealer before I grouted. I noticed splotchiness and dullness in the tiled surfaces. The directions recommended going over the surface with a rag moistened with sealer. Is there a fail proof method or technique for applying sealer. I had a similar problem with a marble install. Can you advise?
