Also, Ditra over OSB??? I wouldn't consider trying to bond anything to OSB.
I wouldn't worry about bonding Ditra to OSB. The shear mass of a 3' wide strip of Ditra is not going to pull OSB flakes off the subfloor.
If you tried to lift a pc of Ditra off OSB after it's cured, the plastic will separate from the fleece first.
Mike is right about the heights. They are your least concern. Having the right subfloor support and correct tile underlayment is more important.
