Hi Steven
The Kerabond / Keralastic is pretty good stuff, but because of its high latex content it would need a couple weeks to properly cure (over Ditra) in dry conditions.
Best thing to do after you demolish the existing bed and tiles is to make sure you have a required slope which might require you to build a mortar bed over the slab. Use latex additive for your mud if you do.
Ditra is a good choice for membrane over the mud bed.
Drip edges are also important on the outer edges of the deck. That can be an extended tile, but best to cover the face of the mud-bed which can be accomplished with a drip edge.
As far as pricing ... Depends how long of a job it is, the difficulty in removal and disposal as well as labour expense of anyone working for you. Take each phase of the project and price it separately on paper and then add in what you need to make in order to make this a good living. If you end up with $175 in your pocket ater a day's work or if you end up with $500, is up to you and your customer.
Also ... a day can end at 2pm or 7pm. If it ends at 2pm there's not much else you can do with the rest of the day except maybe make a trip to the dump ... so no matter what, you've eaten up a day.
Pricing is a very personal thing for each individual and depends a lot on what you consider to be a fair days wage for your services. You decide how long a complete demolishion would take for you and your crew, which would also include setting up drop sheets and dust barriers etc. The time and expence of transporting and dumping at a local waste site. Figure 1 full day for 2 or 3 people. A fair estimate would be between $750.00 and $900.00 just for the demolishion alone.
Building a mortar bed starts at about $7 per sq ft. (more with admix) and then the cost of Ditra and extra mortar. Installing porcelain or high end ceramic should start at $4.25 psf.
Divide the job up into phases Steven and then calculate each phase sepately as an expense .... then add what you need to make to make both you and the Tax people happy.
