Randall: Thanks, I'll probably need all the help I can get. The existing drain pipe from the tub I removed is PVC and above the slab floor. Plus the opening around the drain, from where the forms where (I guess), is not level. As I see it, I'll need to chiesel down to install a new, flush drain and grind the floor level? If so, what is the recommended slope of the drain? Would pictures help, and if so, how do I post pictures? Thanks...Ted
Learn from the mistakes of others, you'll never live long enough to make them all yourself.
