Look into using Wedi board .... it is the only backerboard I'm familiar with which can be used over concrete. (Wedi has insolation properties)
The ditra should be used over top the heating cables, not below.
If you use Wedi and level your cables with a top quality mortar you might get away with not requiring Ditra over top the system.
Wedi comes up to 2" thick although you'd need to check the specs for this type of installation. Perhaps their website may have further information.
