First, let me say THANK YOU to everyone who helped out with my last project. I am incredibly proud of it and it couldn't have been done without this forum. I placed some nearly complete photos of the project up in the finished gallery. Problem is, my wife almost immediately wanted to redo the other bath after seeing how much she loved the one that was finished. Here we go again.
Background:This bath has an alcove tub which was previously surrounded by plaster with tile over it. I believe it had failed and been partly retiled at some point. I am retaining some plaster in the room so I've got a lot of 1/4" shims up to get the plaster height (about 3/4" thick) to roughly equal the CBU height.
Problem:Even with the shims on the studs, the CBU will fall on top of the alcove tub tabs and not lay in front of them. The alcove is retained from the old bath and is set. Here are the options as I see it right now.
1) Just let the CBU lay on top (not in front) of the alcove tabs and have the tiles (brick sized about 4x8) hang down over the tabs and use lots of thinset?? behind them to take up the extra space in front of the tab. The issue of the bottom tile concerns me but the wall will be straight.
2) Use a series of shims at the base or an extra stud nailed to each stud that angles slightly to let the CBU hang over the tab. This eliminates the issue with #1, but I add extra framing and the wall will have a slight bend.
Picture of the area in question (though the tub isn't flush on any of the 3 walls).
Also, is there anything I should place between the studs and the CBU?
