I have a white enamel steel tub that is 5ft long and between two walls. The tub is in excellent condition, but I would like to tile the front skirt to hide the white enamel from an outside view since I will be installing a glass shower door.
I was thinking of using construction adhesive to attach a piece of plywood to the front of the tub skirt (approximately 13" high, then use hardibacker and tile up and cap with about 4" of horizontal tile which the shower door track would mount on top of.
Can someone let me know if this would work or if there is a better way to do it?
Thank you.
