Alex,
Building a shower is the hardest tile project a homeowner could attempt. Not everyone should try. If done wrong it'll leak or look bad. Correcting it will cost 2.5x what the original cost would have been. You can re-read Harry's step-by-step again.
http://www.ontariotile.com/preslope.html1. Silicone under the membrane at the drain.
2. The pre-slope min. 3/8 or so at the drain, rising at about 1/4" per ft. towards the walls. So maybe 3/8" to 1 1/2" or so depending on size of shower.
3. So the weep holes don't get clogged with deck mud.
4. The mesh is only fastened at the outer vertical part of the curb. It will not move inside the mud, guaranteed
5. Backerboard where? Not inside the shower floor?
You can lightly sand the walls and use modified thinset.
www.tile4you.com KERDI Shower Specialist-DITRA Installs-Containers of TRAVERTINE direct, ship anywhere. SAVE 40-70%
