#14673 - 09/14/09 10:17 PM Real Quick Question on laying a New Sub floor
KG14 Offline
Loc: Ontario
Hi grin
I'm getting my 3/4 T&G Plywood in the Morning
Do I Lay the sheets down with the Grain and Tongue going with the Floor Joist(They are horizontal the width of the house) or do I lay them with the Grain going opposite to the joist's
If you need a quick Picture,maybe I can find one to help explain more.
BTW are 1-3/4"x8 Screws long enough
Edited by KG14 (09/14/09 10:26 PM)
#14675 - 09/14/09 10:29 PM Re: Real Quick Question on laying a New Sub floor [Re: KG14]
All plywood always gets installed with the face grain perpendicular to the joists. So the long direction across the joists. I'd be using longer screws and make sure they're not drywall screws.
Pictures are nice. What are your plans for this room? Have you consulted a span chart to verify the joists are up to par if ya doing tiles?
#14677 - 09/14/09 11:00 PM Re: Real Quick Question on laying a New Sub floor [Re: Jaz]
KG14 Offline
Loc: Ontario
I have OSB 5/8's right now and was screwed in with 1" screws and finishing nails and everything else.
I have maybe 3 per joist nails-screws mad
On top of that the Idiots cut the 2x4 Sole for the wall,Then go and hide it with a vanity for the next 20yrs untill we decide to do the bath.
So I'm taking the floor out and putting 3/4 in with Glue etc to make it right
These are the screws I use going to use that I bought
#14681 - 09/15/09 07:45 AM Re: Real Quick Question on laying a New Sub floor [Re: KG14]
Welcome KG14
From this point on it would be better if you keep all your posts related to this one project in one forum thread only. It starts to get too confusing for anyone to follow all the questions and advice when the posts are in different topic areas.
Is this new layer of plywood going over the old subfloor or directly on the joists?
Those are the right screws if your subfloor is going directly on the joists. For second layer plywood installation,the screws should only be as long as the total thickness of the two subfloor panels. The screws should not penetrate the joists. And do not use any kind of subfloor adhesives for the second underlayment layer.
#14682 - 09/15/09 10:24 AM Re: Real Quick Question on laying a New Sub floor [Re: RC]
KG14 Offline
Loc: Ontario
Will Do smile
yes the new Plywood is going right to the Joist's with Lepage Construction adhesive.
Originally Posted By: RC
Welcome KG14
3389 Registered Users
Where do I begin... 51240
Kerdi Board 33028
Kerdi over Denshield 18669
Help with preslope!! 17358
Ted's Shower 12282
3389 Members
