Hi, new member here. I'm a DIY'er who is in the process of working on a second floor addition. My subfloor is 3/4" ply glued & screwed to 11/7/8" WI joists 16" oc with 5/8" ply glued & screwed to the 3/4" ply. Over this I installed Raupanel radiant floor heating throughout. I've put 3/8" ply over the Raupanel throughout except for the two bathrooms. I am asking for recommendations on what I should use over the RauPanel in the bathrooms, continue with the 3/8" ply, thinset, ditra, thinset, tile OR thinset, 1/2" cbu, thinset, ditra, thinset, tile. The main reason I am asking is because as I understand it CBU is not structural and if I go with it it will be installed over the RauPanel which is not secured, it is "floating" until the CBU or ply is installed (screws go throught the CBU or ply and through the RauPanel and into the subfloor. Personally I like the plywood because it secures it nicely but I have never used CBU so I'm looking for some experienced advice. Rehau's instructions doesn't mention CBU.
If your not familiar with RauPanel and you have a minute, the install instructions can be found at
http://na.rehau.com/files/Installation_Guide_855625.pdf Thanks
Gary
