I'm nearing the end of a tub/shower and granite tile installation (I hope!). Tub is in, plumbing done, drywall is up and Kerdi is about to go on.
I need help finding a product to help me finish off the outside corner of a bathtub alcove. Since the rough opening of my alcove was about an inch too large in length, I had to build out the wall on the drain side of the tub. And because of that, I had to also tear off the corner bead that was installed, in order to accommodate. I'm putting the tile right up to the corner and don't really want to put a corner bead back up since they usually don't end up having a perfectly square profile with the wall when finished. I also have to fix up very short section (maybe an inch) of dry wall that was damaged when the corner bead was removed.
I'm thinking of using something like the following Schluter product
http://www.schluter.com/2_7_eck_k.aspxWhat would you recommend??
