As far as I know the vapor properties are the same as Kerdi with the added benefit of some thermal insulation.
As you have seen, the membrane is not actual Kerdi.
The multiple methods for installing the board pretty much cover any job site issues.
Now, if you could use Kerdi fix or HydroBan at some of those corner areas and not have any excess build-ups.
I'll try to see if there is any formal literature at Coverings.
