If it hasn't done it by now then your probably ok to continue on.
I did NOT put down my actual moisture barrier shower liner yet, as obviously that goes on top of this layer. It would serve no good to go UNDER this first layer!
Your absolutely right, but you would not believe how many are actually done that way.
We just want to make sure, so you don't end up creating a big problem down the road.
