#15406 - 02/10/10 05:33 PM DensShield board used in shower
alansievewright Offline
Loc: tottenham ontario
I have poured my first sloped layer of mortar and put down my membrane. I was about to start putting up my densshield boards and noticed that i cannot bury the board in my top layer of mortar, I have to put the mortar in first then put the boards up and Caulk in between, Has anybody used this method? Whats better?? Densshield or cement board.Ive already bought densshield.
#15407 - 02/10/10 11:05 PM Re: DensShield board used in shower [Re: alansievewright]
That's right, Dens can't be buried. Follow the installation spec for a normal pan liner install. Look at page 4 spec DS002 http://www.gp.com/build/DocumentViewer.aspx?repository=BP&elementid=3112
This another option that's approved by Georgia Pacific DensShield with a liquid membrane. http://www.merkrete.com/PDF/GP-Detail.pdf
You could probably substitute another liquid such as Laticrete HydroBan or RedGard, however that would probably void any warranties offered by Georgia Pacific or the liquid membrane manufacturers.
#15408 - 02/10/10 11:25 PM Re: DensShield board used in shower [Re: RC]
I have used dens a lot in the past. It's a good product and you should have no problems with it. Just make sure you tape all seams ad inside corners with mesh tape and waterproof all seams, corners and screw heads with a liquid waterproofing membrane.
#15422 - 02/13/10 02:23 PM Re: DensShield board used in shower [Re: pistolpete]
Thanks Guys Im ready to install the densshield today mortars been drying for two days is there any special type of waterproofing liquid i should use???
#15423 - 02/13/10 02:46 PM Re: DensShield board used in shower [Re: alansievewright]
Depends on what's available in your area.
My personal preference is Laticrete HydroBan, but that may not be easy for you to get.
RedGard will probably be more readily available since it's sold thru Home Depot.
3389 Registered Users
Where do I begin... 51240
Kerdi Board 33028
Kerdi over Denshield 18669
Help with preslope!! 17358
Ted's Shower 12282
3389 Members
