A Kerdi drain will not work. You must use a clamp style drain. Same as the one in the pdf drawing.
Your link to the pdf file worked fine.
If you want to post a photo go to the forum section Ceramic Tile and then the subforum Post Photos your having trouble with. Follow the instructions to post your photos.
