#15596 - 03/10/10 05:51 PM pre-pan pitch
Thor Offline
the distances from the walls to the drain range from 5'(furthest point)on the west wall to 2'(closest point) on the remaining walls. Going by the 1/4" per foot rule how do I keep the north and south wall corner lines level? If I keep the corner lines level will the pitch be too much where the drain is closest to the walls
#15597 - 03/10/10 09:42 PM Re: pre-pan pitch [Re: Thor]
That's usually how it works out. If you've got 1/4" per foot going to the furthest wall, you'll have a little steeper slope on the shorter runs in order to keep the perimeter height level all the way around.
#15599 - 03/10/10 10:04 PM Re: pre-pan pitch [Re: Kman]
That's the reason the drain should be as close to the center as possible.
Also remember to measure from the drain to the corner not the middle of the wall. The corner is usually a good 6" further yet. Also remember the 1/4" per ft. is the recommended min., you could make it 3/8" instead.
#15600 - 03/11/10 03:27 AM Re: pre-pan pitch [Re: Jaz]
Good points, Jaz. You should always measure to the furthest corner.
And I always set the pitch for floors at 3/8" per running foot.
#15604 - 03/11/10 08:59 AM Re: pre-pan pitch [Re: Kman]
Thor Offline
Thanks guys, I can now proceed.
3382 Registered Users
Where do I begin... 50001
Kerdi Board 32372
Kerdi over Denshield 18371
Help with preslope!! 17065
Ted's Shower 12046
3382 Members
3468 Topics
