#16064 - 07/15/10 11:53 PM Tub surround with kerdi membrane
Nammy Offline
Hi all, Yes I'm a newbee smile
I'm getting ready to setup my tub/shower and was wondering what's the best approach?
Install tub, install cement board over tub flange and 1/4" above tub surround, bead of silicon along bottom of cement board and tub, apply kerdi membrane over cement board, tile, and add a bead of silicone between tile and tub.
Does this sound about right?
#16065 - 07/16/10 01:12 AM Re: Tub surround with kerdi membrane [Re: Nammy]
That will work fine. You can also use regular drywall if you want. It's cheaper, cleaner, and much easier to work with.
#16067 - 07/16/10 04:09 AM Re: Tub surround with kerdi membrane [Re: Kman]
Nammy Offline
Thanks,
I think I'll use some sort of protection on the studs prior cement board. (tar paper)
#16068 - 07/16/10 07:36 AM Re: Tub surround with kerdi membrane [Re: Nammy]
You don't want to create a moisture sandwich by having two vapor retarders, such as Kerdi and tar paper. Either use Kerdi by itself, or cement board with tar paper.
#16072 - 07/16/10 01:17 PM Re: Tub surround with kerdi membrane [Re: Kman]
Nammy Offline
Good point
