#16095 - 07/25/10 06:15 PM what's the best granite countertop sealer.
abc Offline
guys need little help here. what' the best granite countertop sealer and where to get it. thanks.
it's a new granite countertops i just installed. they never been sealed. do i need to clean them first with any special cleaners? any info would be greatly appreciated. thanks.
#16098 - 07/25/10 10:08 PM Re: what's the best granite countertop sealer. [Re: abc]
You need to confirm first with the fabricator of your counter tops on what they recommend.
Your top should have been sealed when it left the supplier/fabricator.
#16104 - 07/26/10 10:02 AM Re: what's the best granite countertop sealer. [Re: RC]
abc Offline
i got this straight from the supplier where they cut it. i don't think they seal it. they just buff the top surface to bring the shinessi think. but i will check with them as well. thank you.
#16105 - 07/26/10 11:42 AM Re: what's the best granite countertop sealer. [Re: RC]
abc Offline
i checked with the fabricator it is not sealed. how about penetrating sealers vs non penetrating?
#16107 - 07/26/10 09:38 PM Re: what's the best granite countertop sealer. [Re: abc]
ABC, I have used Aqua Mix products for years and with good results. I would recommend that you call their tech line for advice about which product is best in your situation.
I agree with RC about the slab already having been sealed. I'm surprised that yours isn't. I don't think I've ever gotten a slab for a job that hadn't been sealed by the fabricator. Whether or not they did a good job applying the sealer is another story.
If you don't have access to Aqua Mix products, Miracle in another top-quality brand.
#16108 - 07/26/10 10:15 PM Re: what's the best granite countertop sealer. [Re: Rob Z]
DuPont Stone Tech is another good quality sealer manufacturer.
You might want to do a small water test first to see if you need a sealer or not.
Place a water drop that's about 1" across on the granite. Let it sit for 15 to 30 minutes. It should bead up if there is a sealer or the stone is very dense. If it gets sucked into the stone right away then you need to seal. Just to be sure, wipe up any remaining water with a paper towel and check to see if the granite has changed to a darker color where the water was. If it did, then you definitely need to seal the granite. If it did not change color then your stone is already sealed or is very dense and does not need a penetrating sealer.
#16109 - 07/26/10 10:19 PM Re: what's the best granite countertop sealer. [Re: Rob Z]
abc Offline
hi. the guy that delivered the granite sad no sealer. so i called the warehouse myself they sad it was sealed. i don't know what to believe anymore. if it was sealed can i seal it again with good stuff that way i know for sure it was sealed.
how about penetrating vs non-penetrating sealers. let me know. thanks.
#16110 - 07/26/10 10:22 PM Re: what's the best granite countertop sealer. [Re: abc]
You want a penetrating sealer, not a topical sealer.
Read the manufacturers specs and recommendations for stone sealers that are available in your area.
#16169 - 08/26/10 10:00 PM Re: what's the best granite countertop sealer. [Re: RC]
worst case, your sealer will not penetrate into the stone because it's sealed already and you will just wipe it off. Note of caution: any excess sealer needs to be thoroughly wiped off the surface before it sets. This is usually about 10 to 15 minutes after application. If you fail to get all the excess off you will get hazing or streaks that are very time consuming to buff out.
3389 Registered Users
Where do I begin... 51240
Kerdi Board 33028
Kerdi over Denshield 18669
Help with preslope!! 17358
Ted's Shower 12282
3389 Members
