#16144 - 08/16/10 06:37 PM The best possible substrate
1eyeJoe Offline
Loc: Windsor, Ontario
I'm sure that this may have been asked before (and I apologize if it has) but I'm branching out into a marble floor and it's new to me. I have torn the flooring down to the subfloor which seems like a 1/2" plywood. What would be the ideal level to add to that? Should I use a cement type product, such as Hardi Board, Dens Shield? Should I use Ditra? Is Ditra that much better? I have found Kerdi Board in my city and there is no doubt I will use that in the shower area. Inasmuch as we plan on being in this house for many years I want to do things properly. Any tips on cutting and installing marble? I know I have asked alot of questions and I greatly appreciate any input. Respectfully.
#16146 - 08/16/10 10:39 PM Re: The best possible substrate [Re: 1eyeJoe]
Stone is less forgiving than ceramic tile. You want to take virtually all flexing out of the floor. You can do this any number of ways. Adding 7/8 inch fir plywood, or 1/2 inch hardi glued down with a layer of thinset and screws will do the trick. Dens shield is great for walls, but not for floors. GreenE board (a white cement board)is also good and easier to work with than hardi.
If you have access to the joists underneath install some bridging or blocking every couple of feet.
Use the span calculator on this site to make sure your floor is ok for stone L720 deflection.
White marble needs white thinset, as it it slightly translucent and you can end up seeing ghosted trowel lines. Otherwise marble is easy to cut and shape. I like to take out all the tiles I have and arrange them in a pleasing pattern, matching up the grain as best as possible. keep grout lines minimal and really take care to eliminate lippage.
Green marble needs 100% epoxy solids thinset or it will warp.
