An old thread and my favourite type of bathroom renovation. I love to build curbless showers and there are many ways of doing so. Be careful notching or removing any of your floor joist material. A structural engineer will be required to do this as any modifications of the floors framing members will weaken them.
There are many ways to skin a cat and if you check with your local building department you can get a good starting off point. Often like mentioned in the above post the floor joists need beefing up to allow them to be made smaller.
Smart planning and top shelf water proofing are the keys to any level access shower.
I'm build a new curbless in North Vancouver in my home and will be using a channel drain from ACO in the design. We installed yesterday a Quick Drain USA channel drain on another project that looks amazing.
To get proper answers to building a curbless shower many many questions need to be answered. Find your top setters, builders, renovators in your home town and set up appointments with each. Check with your local building department to see if any curbless showers have been built in your area.
Research the subject and find design elements you like.
www.houzz.com is a good source for pictures. Armed with your wish list, home plans and coffee start the process of designing your new curbless shower with the help of your local top trades.
Good Luck.
John Whipple
North Vancouver
"When it's perfect. It's good enough."
