Saturated Surface Dry treated the plywood and put down thinset and Ditra today--back tomorrow to start tiling.
Can you elaborate on that one?
As long as you have 90 to 100% coverage under the stone where the feet sit, you will likely be ok. Make sure the coverage is full under the foot locations to properly take the point loads.
Double check the marble pcs that are going to sit under the feet for pronounced veining to help eliminate the potential problem for cracking.
Not sure what you mean by isolating them with silicone? Grout joints?
