#16543 - 01/04/11 12:07 PM Shower Leveling
KJW Offline
Loc: Minnesota
I am in the process of building a tile shower. 34 x 48. I will be using the
pre-sloped styro base with the membrane/drain kit etc.
The underlayment is not flat/level and has a gradual slop of about 1/8-1/4(Rough guess based upon my initial level reading). It starts about 3/4's of the way and not the whole length of the shower.
I was planning on putting a 1/4 Hardibacker board on the floor also for additional support over the 3/4 particle board as I have to patch the drain area where the plumber did some work. (I will be replacing a section of particle board and then the HB board)
Long story short, what is the best method to level. Use a self-leveling compound or can I use a thinset to smooth out? Should I level on the particle board or install the HB and then level?
Thanks.
#16545 - 01/04/11 06:16 PM Re: Shower Leveling [Re: KJW]
Are you sure this is particle board and not OSB?
Particle board looks like compressed sawdust, because that's basically what it is. OSB looks like chunks and strands of wood. There's a distinct difference in the two. While neither of them are as good as plywood in my opinion, OSB is light years ahead of particle board in stability and strength.
If you do have particle board, you will want to remove it and replace it with OSB or plywood. A little bit of water will cause particle board to swell to several times its original thickness, then deteriorate and fall apart. You definitely don't want something this unstable under your shower.
If you do have to remove it, you will be better off getting your floor level and flat from the joists up. This will also give you the opportunity to take care of those areas that now need patching. You don't want to use 1/4" hardibacker for repairs as it doesn't have the strength of plywood and OSB.
#16546 - 01/04/11 06:28 PM Re: Shower Leveling [Re: Kman]
KJW Offline
Loc: Minnesota
Sorry. It's OSB. 3/4 subfloor. I am going to cut a small section out to patch the small opening the plumber created. I will patch with the same OSB and then cover the OSB with HB. (Sorry if I wasn't clear as I know HD doesn't have the structural strength. I want to avoid having to cut the entire subfloor out as it seems it should be able to be leveled without doing this.
Given my clarification, what's the best way to proceed? Thinset then HB, HB then thinset, or thinset and let it cure and then just apply another layer of thinset to set the styro pan?
Sorry for the confusion.....
Edited by KJW (01/04/11 06:30 PM)
#16547 - 01/04/11 07:24 PM Re: Shower Leveling [Re: KJW]
Ideally, you would use a mud preslope which would take care of the unlevel floor. If that's not an option for you, then you can use thinset to level it, provided you don't build it up more than 1/4". You may have to let it dry more than a day.
There's really no use for the Hardibacker that I'm aware of, unless the manufacturer of that styro base requires it.
Is this a Kerdi shower?
#16550 - 01/05/11 11:39 AM Re: Shower Leveling [Re: Kman]
KJW Offline
Loc: Minnesota
It's a Prova Shower Kit. As I can tell and be told similar to the Kerdi. It was just easier for me to get access to.
Correct. I don't have to have HB for based upon the installation directions, I just thought it would provide a more "refined based." However, more work on my part....
I most likely with use the thinset to level the areas.
Anything else I should be aware of?
#16551 - 01/05/11 04:02 PM Re: Shower Leveling [Re: KJW]
I'd say the Hardi is definitely optional for you, then.
Best advice I can give you: Take your time. If you feel like you're going to have to rush the project or any part of it to get it done on a certain schedule, wait until you have more time. Nothing worse than looking every day at some job you did and wishing you had done it better.
#16552 - 01/05/11 09:03 PM Re: Shower Leveling [Re: Kman]
KJW Offline
Loc: Minnesota
Thanks for the tip. It's a bathroom remodel for our family. We have other bathrooms we can use and it doesn't have to be done on any certain time schedule. I am thankful for at least that much. I have done enough tiling to feel confident, however, not with a shower and water. So I want to make sure I get it right even if it takes me 5x's as long.
Thanks for the prompt replies. I am sure I will have other questions as I proceed.
#16556 - 01/06/11 08:37 PM Re: Shower Leveling [Re: KJW]
Sounds to me you have a hole around the drain that is a little too large. I recommend installing some 3/8" ply. Level the floor with thin set if it's not off too much. Hardie will do you no good.
#16557 - 01/06/11 10:38 PM Re: Shower Leveling [Re: Jaz]
KJW Offline
Loc: Minnesota
Correct.
The area around the drain was too large to start and then the plumber had to cut out another section to center the drain, making the hole irregular.
Are you saying to level the floor and then the 3/8 plywood over the whole base? (Not patching)
I was going to just cut/patch, make the drain area tighter, level, and then install the HB just as a final surface. I know it can't be used as a structural support.
The 3/8's plywood sounds like a better option....
#16558 - 01/07/11 09:12 PM Re: Shower Leveling [Re: KJW]
Hardie will do no good under deck mud, use plywood if needed. 3/8" would be the minimum, thicker is better, all depends on how large that hole is.
Level the floor after you install the plywood.
