I would install 1/2" underlayment grade plywood over planks due to the probability of slight cupping of the planks. Especially if the planks are not t&g.
Schluter has a 2" min for tiles over Ditra as Kevin mentioned. I think you could disregard that if you first fill all the squares with thin set and set the tiles the next day. This will void any warranty you might have expected. Me, I don't expect any warranty.
I believe Schluter's position is in regards to heavy loads such a heavy table legs on a small area. I'm sure they will stick to their recommendation as well they should. Otherwise any CBU is just fine. You do not need 1/2". I recommend 1/2" ply, then 1/4", 5/16" or 3/8" concrete backer.
www.tile4you.com KERDI Shower Specialist-DITRA Installs-Containers of TRAVERTINE direct, ship anywhere. SAVE 40-70%
