Thanks guys! Densshield is mostly on. I work on wooden boats too. It's curious to me that no one mentions polysulfide calk or the 3M 5200 (one part polyurethane)in some of these threads. I plan on calking the bottom of the denshield (between denshild and mudbed) with 3M 5200 which is another under water calk for thru hull fittings. This is used on hull of the boats, and for all sorts of reasons. Sticks and stays. It's just not fast. Can come in some different colors. I do not like the performance of silicone calk in real wet envirements but maybe that was years ago. Has it changed?? I'll have about a 3/16 gap at the bottom of the denshield and between each sheet I calked with butly rubber and pushed it together. Now I will tape the seems per instruction...
I saw one of the examples Mr. Dunbar showed making a mud bed and he slatherd latacrete on the mudbed which made me think I have to. It looked like a similar set up as mine. Also in these threads, I saw a lot of references to waterproofing all of the fasteners. I really want to do this as right as I can. Perhaps should have gone with the cement board as kerdi isn't too available for me, joe amature, as far north as I am.
Thanks again, didn't expect an answer so quick!
JFK
Jim Kaiser
