Why not set directly on the plywood with a modified thinset? 2 layers of 3/4 is plenty strong enough.
Because we want Kdog to do a real good job.
Two layer of 3/4" subfloor is a bit overkill, but the concrete backer or matting is the set the tiles on a "tile friendly" surface. Plywood is NOT tile friendly.
Kdog could have chosen a membrane which are from about 1/16" to 1/8" thick. Or 1/4" concrete backer instead of 1/2".
www.tile4you.com KERDI Shower Specialist-DITRA Installs-Containers of TRAVERTINE direct, ship anywhere. SAVE 40-70%
