You would do the electrical after the framing, then insulation.
As for the vapor barrier, I think the sealer you put on the blocks may suffice, depending on what you use. However, vapor barrier is not something that's used in my area, so I'm not sure about that. Maybe RC or someone with more experience with the use of vapor barriers can advise you on that.
