Some people don't want much of a curb. Typically I build the curb using 3 - 2x4's.
I wonder how thick the mud is?
Did the plumber install the drain and pan liner? If so, you really need to verify the above points.
I agree with that. I've never seen a pan installed by a plumber that was done right. The main fault, no pre-slope. 2nd problem, pan installed so that you could only do a mud job on the walls, cuz of the way it was folded. Too bulky.
Of course if you install board at and on the curb, you've destroyed the membrane and need to apply a surface waterproofing. Of course most don't and just cover it with tiles only to leak one day.
www.tile4you.com KERDI Shower Specialist-DITRA Installs-Containers of TRAVERTINE direct, ship anywhere. SAVE 40-70%
