#17168 - 08/17/11 01:25 PM Just beginning
sassi Offline
Loc: Jackson, MI
Okay, I have been looking at the bathroom and have remodeled it in my mind. Time to start asking questions about what I need to put this into reality. I have a basement bathroom that has poured concrete walls and linoleum on the floor. There is a teeny tiny itty bitty prefab shower and I want to put in a larger shower. I had thought about prefab but since I want to use the existing drain, I have decided to try to do a mortar base and tile. I haven't taken the existing shower out yet so I may be in for more surprises when I do but my initial question is what will I need to do in order to be able to tile the concrete walls? Would applying Kerdi around this make it an "easier" project?
#17169 - 08/17/11 10:30 PM Re: Just beginning [Re: sassi]
Kerdi is definitely an option. By far the easiest solution is to re-locate the drain and use a pre-fab unit. However, if you're set on tiling consider a Schluter shower kit or a liquid waterproofing membrane like Aquadefense. Use a Schluter drain unit regardless. Read a lot first and then decide. You should know that a custom shower with pan, niches, etc takes a professional setter about a week to complete. For a DIY project you should allot about two weeks. This is what makes moving the drain so simple by comparison.
