#17206 - 09/08/11 08:29 AM Tiling a dry outdoor porch
Hosh Offline
I am finishing an outdoor screened in porch. The windows are screened with a product called Weather Master so the room will not get wet when raining. However the room is not heated and will experience the cold temps of northern Ontario. I have purchased ceramic tiles for the floor. The floor is pressure treated plywood. The room is 115 sq.ft. What is the best method to install the tiles.
Hosh
#17209 - 09/08/11 10:51 PM Re: Tiling a dry outdoor porch [Re: Hosh]
Hi Hosh,
So you're saying this special screen will not let water in? I thought Weather Master was a brand of windows. I've never heard of "magic" screen.
I'll need more info as to how the framing is built and with what. How high of the ground. Type and size of joists, species of wood, grade, on center spacing of the joists and unsupported span of the joists to the inch. This is to verify the floor is stiff enough for tile. Sometimes people build a room on an old deck which usually doesn't meet standards for tiled floors.
I can tell you that the pressure treated plywood is the worst thing you could have chosen as the subfloor. It's very unstable, (unless it's kiln dried) and is not for interior use. It'll probably be OK to keep it, but you'll want to cover it with the proper plywood underlayment and then concrete backer thin setted to the ply, or Ditra matting. The tiles should be a frost proof type, such as porcelain. There's much more to it. Lets start with the framing info.
#17263 - 09/17/11 10:26 PM Re: Tiling a dry outdoor porch [Re: Jaz]
rosecamoro Offline
Jaz is right! Any photographs? Plywood will not cut it And its a outdoor porch, it will be tested by the weather.
pebble floor tiles pebble floor tiles
#17365 - 11/13/11 10:26 PM Re: Tiling a dry outdoor porch [Re: rosecamoro]
hewittile Offline
Okay, I know a little bit about this. First install a kerdie membrane over the plywood and seam all joints, than install your ditra membrane over the top of this and seam this, allow for a "bara flashing" by schulter if needed. If you have any water penetration at wall areas be sure to install kereick first before the kerdie. This method only works for porcelain tile or ceramic, stone applications require another spec. You must also provide for an expansion joint if your project is less than 8-12 '
#17370 - 11/15/11 11:17 PM Re: Tiling a dry outdoor porch [Re: hewittile]
Hewittile,
Where did you get that info from? Since when do you install Kerdi over ply and then Ditra? That's all wrong or did you misspeak.
#17397 - 12/02/11 11:55 PM Re: Tiling a dry outdoor porch [Re: Jaz]
hewittile Offline
Jaz, sorry it took so long to get back, check with your schluter rep, this is the prefered method of installing porcelain tile over plywood at a deck area. Once again, kerdie, ditra,and the tile. This is what my Western rep told me, also I do have the paperwork on this and will dig it out when I can. Currently am in the process of installing porcelain tile at an exterior deck using this same process.
#17399 - 12/03/11 07:51 AM Re: Tiling a dry outdoor porch [Re: hewittile]
The Schluter handbook specifies Ditra, Kerdi on the seams, then tile. There are a number of approved substrates (eight, to be exact) for Kerdi. Plywood isn't one of them.
#17401 - 12/03/11 05:57 PM Re: Tiling a dry outdoor porch [Re: Kman]
I agree with Kman. Never seen or heard of the method hewittile is describing.
Hope Hewittile can back up that method with an actual Schluter written specification.
Until such time I would ignore that method.
#17402 - 12/03/11 06:15 PM Re: Tiling a dry outdoor porch [Re: RC]
hewittile Offline
Okay ! I agree with kman and all who say that until hewittile can back that up with specs, forget about this method. I am looking at the schluter systems now, you will find this method under " ditra drain" at the schluter web site. I probably was not clear enough when I said " ditra" this is their drain system and still un uncoupled membrane, I will let you know in a couple of years as I am installing tile at an outdoor porch using this method. The schluter rep... 888-8531
#17404 - 12/03/11 06:32 PM Re: Tiling a dry outdoor porch [Re: hewittile]
Sorry I have no clue what your looking at.
The approved method is very clear in the Ditra Handbook specifications for exterior porch installations.
The only reference to Kerdi is for banding the seams only and the wall transition on Ditra.
