#17375 - 11/20/11 09:19 AM
Tilesetter in Mississauga (Greater Toronto Area)
Loc: Mississauga, ON
I was wondering if anyone can help me find a reputable tilesetter in the Mississauga / Toronto area. I have Travertine tile, Marble Tile and Porcelain tile that needs to be installed over the whole house (i.e. bathrooms, showers, laundry, kitchen, foyer, and so on...).
#17376 - 11/20/11 03:58 PM
Re: Tilesetter in Mississauga (Greater Toronto Area)
[Re: Nino]
Hi Nino, Good question. This site's homepage, http://www.ontariotile.com/ used to have a link called Ontario Tilesetter Directory at the very bottom, - http://www.ontariotile.com/directory.html The link does not take you to a list arranged by location anymore. You can still find names though by going to the user list; http://www.backyardforums.com/forums/ubbthreads.php/ubb/showmembers You may find the list handy. Use it as a guide. You may not be aware that natural stone tiles require a much stiffer subfloor system that ceramic tiles. Also do not let anyone talk you into what is known as a "scratch coat" job. This is wire lathe over plywood then thin set mortar and tiles. It's a non approved method with a high failure rate. Get back to us once you start talking to a few tile setters. Jaz
#17377 - 11/21/11 07:07 PM
[Re: Jaz]
Nino, I know a guy in Mississauga that will take good care of you. Drop me a personal message and I'll fill you in.
#17432 - 12/08/11 07:15 PM
[Re: Jaz]
why are people against scratch coat installations,, I find it very eficient???
#17433 - 12/08/11 07:20 PM
[Re: murraymmb]
I can actually build a proper showr with no leaks (40 years) on this method,, However,, I am finding the Kirdi membain to be a very substantial bennefit to showere installations,, all though,, I dont find it needed to use there drain system in all applications
#17524 - 01/17/12 11:17 PM
[Re: murraymmb]
It took me about a month to educate myself about tiles. I have decided on 24" by 24" porcelain tiles for the kitchen, due to the low maintenance.
#17528 - 01/18/12 10:17 AM
[Re: Jaz]
Hi Nino, Good question. This site's homepage, http://www.ontariotile.com/ used to have a link called Ontario Tilesetter Directory at the very bottom, - http://www.ontariotile.com/directory.html The link does not take you to a list arranged by location anymore. You can still find names though by going to the user list; http://www.backyardforums.com/forums/ubbthreads.php/ubb/showmembers You may find the list handy. Use it as a guide. You may not be aware that natural stone tiles require a much stiffer subfloor system that ceramic tiles. Also do not let anyone talk you into what is known as a "scratch coat" job. This is wire lathe over plywood then thin set mortar and tiles. It's a non approved method with a high failure rate. Get back to us once you start talking to a few tile setters. Jaz Hi Jaz, can you recommend a cheap place to get ditra?
