I agree with Pete, you should be Ok as is.
However, in # 2 you said;
2. I know I was supposed to use unmodified mortar between the Kerdi and the substrate but I mistook the DITRA instructions and used Laticrete 255 modified. Am I likely to have problems ? Will an extended drying time help ?
Good thing you used modified to bond to the plywood. Had you used unmodified, (as you think you should have), I would be telling you to start over now. For both Ditra and Kerdi you have to use a "substrate appropriate" thinset, and unmodified will definitely not work over wood.
www.tile4you.com KERDI Shower Specialist-DITRA Installs-Containers of TRAVERTINE direct, ship anywhere. SAVE 40-70%
