First of all - thanks in advance for any input provided. We moved into our home last September and have never completed the master bath. Everything is plumbed. I've attached a couple of photos of what we have planned, but I have a couple of questions (that will probably turn into hundreds!!).
1)The tub is functional, the guy that does the trim work wants to detach the drain, etc. and build a support for the tub to rest on. Can we just "back into" the height that would allow us to tile "up to" the bottom edges of the tub?
2)The half wall that will be between the tub and the shower will not line up on a stud on the main wall. Since this wall will be completely tiled (shower side & tub side), do you guys think I can make this wall strong enough to support an accidental bump by someone while showering??
Here are the photos..
