Hi Will
Glad the information here has been helpful.
Can I use more thinset on one side to elevate the base?
I think you might create an unlevel pan if you do that.
Those pre-fab Kerdi pans are nice, and they're easy to install. But they don't always fit every application.
I agree with Randall that a mortar bed is the ultimate .... BUT, you can use the Kerdi kits. When you trim edges to make them fit, try to take equal amounts off both or all sides so that the perimeter height remains constant. Also ... instead of trying to add mortar under the foam kits to raise them ... add it to the top instead. Try to be neat and apply a smooth application where needed.
