....Onto my new problem (challenge).
Last May I started out re-doing my bedroom's ensuite bathroom (simple toilet - sink scenario in a 5' X 5' space).
I gutted the whole bathroom and had to rebuild the subfloor (thank you for this forum's advice).
I've installed Ditra and am ready for tiling. I plan to use tile as my baseboard around the bathroom's perimeter.
After looking closely, what seemed like a decent to good drywall installation (and joint finishing) is actually not so great since the walls are "wavy" and installing rigid baseboard tiles may not be wise (1/4 inch gap in the center of the wall is evident when I hold a 4' straight edge against it).
I'm thinking of correcting the gap at the base using drywall mud.
Specifically:
1. What would be the best way to rectify this situation? I have 2 walls with this problem.
2. Can I go ahead and install the floor tile regardless of the method of correcting the wall gap situation.
3. When installing the floor tile, would you recommend having the floor tile go underneath the drywall or have the tile edge aligned with the drywall face? I would think that this would influence my decision to add the "Kerdi Band" along the wall-floor (Ditra) surface.
As always, thank you for your feedback!!!
