#8395 - 11/12/06 12:38 AM Basement Shower - redoing drain question
pmacaula Online   content
Loc: Toronto
I have just finished stripping a leaky old shower stall in my basement down to the studs and cement floor (took the shower pan out too). Am replacing most of the studs due to mold at the bottom.
Intent is to rebuild a tiled shower stall with door in the same place.
The concrete was not level, had large cracks and was not securely holding the drain in place, so I made the (possibly foolish) decision to break it up and remove it - leaving dirt.
Current plan is to have a plumber in to redo the drain/p-trap before I lay down new concrete sub-floor, then concrete board walls & do the full Schluter shower system before laying tile.
Want to ensure the plumber leaves things the right way.
I think *but am not sure) the right way to go is to have him leave the new 2" (p-trap a few inches below the bottom of the concrete subfloor) pipe sticking up a foot or so with a 4" diam spacer pipe around it.
Assume I then pour the concrete sub-floor, let it dry and cut the 4" spacer pipe flush w/ the surface. Next cut the 2" pipe to attach the kerdi drain to it to fit with the pre-sloped kerdi shower pan on top of the concrete.
Other route that I can think of is to have the plumber attach the kerdi drain to the 2" pipe (no other 4" spacer around it) and then pour the concrete subfloor.
Don't want to 'set things in concrete' the wrong way & have to chip it all out.
Any help greatly appreciated.
#8396 - 11/12/06 06:48 AM Re: Basement Shower - redoing drain question
The Kerdi tray is not that thick where the drain sits so you will need to have the 4" pipe spacer placed in the concrete pour to allow for the wide portion of the Kerdi drain to fit.
The center section is detachable from the tray so you can have the plumber dry fit everything to the right heights.
#8397 - 11/12/06 09:07 AM Re: Basement Shower - redoing drain question
Loc: Toronto
Randall - thanks very much for the quick and clear reply.
Two follow-up questions:
1. I have the Schluter kit here - What is the best way to mark the target height of the top surface of the kerdi drain for the plumber ?
2. What is the best concrete to use for the subfloor ?
Assume I have to project the top surface of the concrete sub-floor plus some space for the mud bonding the kerdi tray.
The old concrete was max 2" thick - not sure that meets current code. Want the floor as low as possible (I'm a tall guy & in the old shower stall, my hair brushed the ceiling), though assume top of slab in the rest of the bathroom (not broken up) is a good starting point.
Cheers. Patrick.
#8398 - 11/12/06 08:19 PM Re: Basement Shower - redoing drain question
It sounds like you have removed the existing shower pan plus the entire concrete slab under the pan. Is this correct?
Remove the center section of the Kerdi tray and use it as a guide for the plumbing rough-in height. You first need to determine your final slab height then using the Kerdi tray pc and Kerdi drain you can calculate the stand pipe height.
Use regular pre bagged concrete mix.
Concrete should be a minimum 3" thick for non load bearing slabs.
#8399 - 11/12/06 11:35 PM Re: Basement Shower - redoing drain question
Loc: Toronto
Randall,
You are correct - have removed all of the concrete so the plumber can get at the p-trap.
Your answer makes sense, though my main anxiety is projecting the final slab height before pouring it and permanently fitting the kerdi drain before doing so.
After reading your answer, and watching the Schluter video, I think I missed something pretty obvious & am now thinking through the installation this way....
When the plumber puts the new p-trap in, he can dry-fit a 2" standpipe (length not important) and put a 4" spacer around it. I then pour the concrete sub-floor around the 4" pipe.
After the concrete dries, I cut the 4" spacer flush to the surface, remove the dry-fit standpipe, position the Kerdi-drain over top (w/ centre section of the Kerdi shower pan underneath it) and measure for the length of standpipe req'd. Then permanently fit the cut-to-length standpipe.
Next, mud the concrete and put down the Kerdi shower pan. Then lay down mud on the centre section and permanently fit the Kerdi drain into the 2" pipe while pushing it into the mud.
This saves me from permanently fitting the Kerdi drain or cutting the stand pipe before laying the concrete.
Does this make sense or have I missed something again ?
#8400 - 11/13/06 08:02 AM Re: Basement Shower - redoing drain question
You got it exactly. \:\)
#8401 - 11/13/06 07:29 PM Re: Basement Shower - redoing drain question
Loc: Toronto
Randall - thanks very much. The quality of your answers and speed of turnaround (same can be said about quite a few of the senior members of these fora) is truly incredible.
Will likely have a number of additional questions as I go through the project (which now includes putting down underfloor heating).
In a small attempt to give back, will post photos of a few key stages in the build.
Cheers.
#8402 - 11/13/06 07:34 PM Re: Basement Shower - redoing drain question
Loc: Toronto
Cheers.
#8403 - 11/16/06 01:26 PM Re: Basement Shower - redoing drain question
BJ James Offline
Loc: Grand Bend, ON
Unless I'm mistaken, you will want to remove the 4" spacer pipe after the concrete sets, but before it completely dries, since the Kerdi drain is 4" at the thick part where it flanges up. That section will be below the top of the slab unless you have built it up higher.
Your project sounds identical to one I'm working on.
Check this out: kerdi drain rough in
BJ
#8404 - 11/16/06 07:20 PM Re: Basement Shower - redoing drain question
RandyL Offline
Loc: York Region
maybe I'm missing something here. Make sure that your kerdi drain is glued in place first at the right height. You need to set the drain in place before you mud around it. Don't try to glue it afterwards, it may screw up. If you have a schluter tray then the blocks that come with the drain tell you what your finished floor height should be.
If you already know this , then sit back and drink beer!
