Ralph, if you want to avoid the isolation box, look for a fixture with the "IC" rating on it. This stands for "insulation contact" and is designed for insulation to be in direct contact with it without overheating or burning the insulation. It has a thermostat that turns the bulb off when the temp gets to a certain level.
