At this point you should use thin set. You'll have to apply it...well....thin. So if you have to give a a couple of coats, then that is better than one heavy coating. Thin set is sticky and hard to trowel smooth...plus too thick will shrink and crack. Give it a skim coat, and then an hour later, you should be able to give it another coat.
