I've finally started the final bathroom and have the walls down to the studs, and the old tub out.
When I frame the 18" deep x 18" high x 5' long bench along the back wall, I planned to cover it with 3/4" plywood and then install the Schluter Kerdi 32" x 5' kit in front of the bench with floor to ceiling glass to enclose the steam/shower.
Should I use Ditra on the two bench surfaces, or is the Kerdi sufficient?
Thanks one and all for all your inspiring projects and advice.
Pictures will follow when complete, promise!
