Hi Harry, I like that way with cinder blocks and would of done it that way had I found this site earlier, but the pan is in framing is done floor is alread mudded all I have left to do is mud the curb, put the cbu on the face of the seat, mud the top of the seat and I am ready for tile. problem I have is when i screw on the cbu to the face of the seat I will be penetrating the liner and I don't want it to leak. Here is a quote from askthebuilder.com "Waterproofing is accomplished by using the vinyl membranes that are used beneath ceramic tile floors. Simply purchase and install a continuous sheet from the floor, up the front of the bench over the seat and up the back of the seat wall about six inches. The membrane is only nailed at the top edges. You will have to penetrate the front bench wall surface with nails when you install the vertical piece of cement board. This is not a problem, as I have yet to develop a leak in my shower after 15 years." I don't beleive it won't leak. should I use kerdi membrane over the cbu to seal it? thanks for your help.
