#9009 - 09/19/01 10:00 PM Backer rod
Ron Offline
Hi,
Where can I buy this foam backer rod that I hear about? It's used in movement joints to apply caulking onto.Never used it.Don't know where to buy it in Toronto and surroundings.Anyone know?
#9010 - 09/19/01 10:37 PM Re: Backer rod
Hi Ron
You can sometimes get it from a window and door/glass company...but I think you can also get it from Mcnaughton-Brooks(which I think is Masterbuilders these days...just down the street from Olympia Tile..on the same side as Olympia's clear out center....maybe even Domus would have it(next door)
#9011 - 10/16/01 08:03 PM Re: Backer rod
tileprof Offline
Loc: vancouver bc
ron i can't believe you never heard of backer rod! what have you been using?
#9012 - 10/18/01 08:14 PM Re: Backer rod
Ron Offline
Hi Tileprof,
I'd always heard of it but could never find it even after extensive calling and searching for years.
I always use Schluter's Dilex for field joints.At perimeter joints against masonry I would fill them with either silicone or urethane caulk.Would be easier to do with backer rod,then caulking.
Back from Arizona,Tileprof?
#9013 - 10/19/01 09:16 PM Re: Backer rod
John Bridge Offline
Loc: Houston, Texas, US
Steven,
A lot of people don't know about backer rod. I only found out about it a couple years ago.
Seems like only yesterday, though . . .
#9014 - 10/29/01 04:48 PM Re: Backer rod
Mike Stewart Offline
Loc: Toronto
I hate to sound dumb but what is backer rod and what does it do?
Mike
#9015 - 10/29/01 05:24 PM Re: Backer rod
Hi Mike
Backer rod is a foam rod that is used to fill a gap the is too large to fill with caulking alone. Some control joints in a concrete slab go down quite a way, and to fill this with caulking would take many, many tubes. The backer rod is stuffed into the joint,down far enough to be hidden, but leaves 1/4 to a 1/2 inch space for caulking. It comes is lots of different sizes, depending on the size of the crack you need to fill. It comes on a roll, just like rope..only it's foam.
Brian ;\)
