Ceramic tile installation tips - Renovations using Ceramic tile or Stone
Maximum Span Calculator for Joists
Sponsored Links
Post Your Photos!
bamboo porcelain
travertine shower w/ glass mosaic inlay
final pics of marble shower and bath
Marble shower/bath
Heated floor in a steam shower
Search
Page 2 of 2 < 1 2
Topic Options
#14226 - 05/21/09 02:13 PM Re: Ditra and Cracking [Re: Bri]
Kman Offline
Senior Member
Loc: Pea Ridge, Arkansas
I have had two instances of grout cracking in the past year, and both of them were with the same builder. One of them was on Hardibacker, and now this one on Ditra. Both of them are on a single layer of 3/4" Advantech. I'm not sure this guy is even going to be doing any more construction with the economy the way it is, but I'm thinking if he does, I'm going to strongly suggest he go with single layer plywood or a double layer of OSB.
Some of problem might also lie with the framers. If they didn't level that wall perfectly with the other walls, that could cause the problem. We've also had some pretty wide temperature swings over the past few weeks, and a crapload of rain. Don't know if those might be a factor.
_________________________
The top ten reasons to procrastinate:
1.
Top
#14501 - 07/24/09 11:21 PM Re: Ditra and Cracking [Re: Kman]
Bri Offline
Senior Member
Loc: ontario, canada
Well today, I finally pulled up some of the tile that has cracks around the entire perimeter of each tile....AND......they are stuck down really well...nothing is loose...the Ditra is well bonded to the plywood subfloor...the tile is well bonded to the Ditra. I don't know what to say. It's as if the movement is sideways..and Ditra is supposed to address that issue. I may give up on the stuff in High Traffic areas. Lucky(or not) this is my brothers house. If it weren't I would be totally screwed right now.
Brian
Top
#14504 - 07/25/09 05:25 AM Re: Ditra and Cracking [Re: Bri]
Kman Offline
Senior Member
Bri, have you mentioned this to anyone from Schluter? Maybe they could offer an opinion on the problem.
1.
Top
#14506 - 07/25/09 08:49 AM Re: Ditra and Cracking [Re: Kman]
Bri Offline
Senior Member
I haven't. I'm afraid my sister-in-law will find out the reps name...and..well......I don't want to be responsible for what might happen wink
Plus....I used modified thin set for everything..so, I just figure they'll tell me that was the problem. But now that I see the bond is fine...I think I will tell them.
Brian
Top
#14550 - 08/05/09 01:41 AM Re: Ditra and Cracking [Re: Bri]
Kman Offline
Senior Member
Got another one. mad
This is one I did earlier this year. Three different areas of tile, and one travertine. Not one tile is cracked, but there are hairline cracks in different areas. Even the grout with the travertine is cracking. I figured if it was a deflection issue, the stone would crack too, but it hasn't, and it's on Ditra XL. They've installed cabinets, a stove, and a refrigerator on this travertine and it appears to be holding up okay, but the grout has hairline cracks. I'm about to my wit's end on this.
If I just knew what the problem was, I could address it, but I can't seem to figure out what's causing it. frown
1.
Top
#14553 - 08/05/09 08:16 AM Re: Ditra and Cracking [Re: Kman]
Bri Offline
Senior Member
Funny enough...I am doing a shower right now...the rest of the room is done already...many years ago...old ditra...with the ribs. I can take the whole floor out in one piece. Not one crack in the joints though. How weird is that?
Brian
Top
#15588 - 03/08/10 05:39 PM Removal of old adhesives before laying porcelain [Re: Bri]
bebe Offline
New Member
This post has been moved to its own thread.
Edited by RC (03/08/10 06:22 PM)
Edit Reason: Moved Topic
Top
#15723 - 04/02/10 11:46 AM Re: Removal of old adhesives before laying porcelain [Re: bebe]
KG14 Offline
Member
Loc: Ontario
Any pics yet
Top
Page 2 of 2 < 1 2
February
Su M Tu W Th F Sa
1 2 3 4
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29
Newest Members
abelabbey26, kuro, Deadeye, Murphy, dukefan3414
3387 Registered Users
(Views)Popular Topics
Where do I begin... 51078
Kerdi Board 32934
Installing Nu Heat on Cement Slab 22821
Kerdi over Denshield 18647
Help with preslope!! 17328
Self-leveling compound on plywood 15616
slate tile on heated floor 14055
best liquid waterproofing? 13201
Ted's Shower 12250
tiling around shower drain in conrete basement 11387
Forum Stats
3387 Members
16 Forums
3472 Topics
Max Online: 505 @ 02/07/12 09:26 PM
Who's Online
5 registered (kuro, abelabbey26, pmacaula, Deadeye, 1 invisible), 370 Guests and 8 Spiders online.
Key: Admin, Global Mod, Mod
RSS Feed
Subscribe to our RSS Feed
Home    Forum     Technical Info     Our Service     Photo Gallery     Installation    Contact Us    Privacy     Links    Books
